Tue Jan 16, 2018 12:08 am
#1584428
The Dunsfold ILS did have an associated DME zeroed to the threshold.
smokescreen wrote:The Dunsfold ILS did have an associated DME zeroed to the threshold.
The DME at Farnborough is positioned midway between the two thresholds and is 'zeroed' at the thresholds, so if you're using it for the noise abatement departure procedures, you MUST take the reading from the second 'zero' point not the first.
smokescreen wrote:The CAA wouldn't allow the use of Pease Pottage (SSR only even though Pease primary was also fed in)) unless a safety case was written!
Cookie wrote:I suspect, when applicants present for test, any aeroplanes with an ADF fitted will now have an INOP sticker across it!
Cookie
