By Rob P
#1851391
Avoiding thread drift elsewhere ... I wonder does anyone have real world experience of the performance differences between the taildragger versions and the original monowheel retractable? (Given identical engines, of course)
No I am not in the market, just intrigued. Someone in the US built a retractable Van's and the performance gain was depressingly small.
By Big Dex
#1851401
Whilst I appreciate that this is not the question asked, I have a 100hp VP XS Trigear with the speed kit fitted. It’s around 6kts slower than the equivalently equipped mono wheel, or an additional 1lph if you prefer. 130kts at 20lph, give or take.
I’d expect the tail dragger variant to fall somewhere between the 2.
The speed kit makes a big difference to the Trigear (10kts), and a smaller benefit to a mono (5kts I believe).
Rob P liked this
By PeteSpencer
#1851415
ANRMan of this parish has a rather gorgeous Tri gear Europa, whose take off performance from Knettishall was startling.
Ask him.............. :wink:
By Rob P
#1851417
Well his contribution on Tri-gear performance would be interesting, but doesn't get me any closer to answering the question I am asking.
By Rob P
#1851430
I suppose I was looking for real world experience of the taildraggers, much as in my original post.
By Volare
#1851473
@Rob P
An interesting question but I doubt you will be able to get an apples to apples comparison. All Europas are hand built, so all are different. Some have speed kits, some don’t, some have VP props and some don’t (several makes of either prop fitted as well), some are ‘classic’ builds and some are XS. There are about 3 different variants of taildragger Europas, the ‘Swiss mod’, the Miles McCallum Flyer Mod (only 1 of those presently) and in the US the Berube/Grove version. Then there are different engine options from Rotax 80 – 115 hp to Jabiru 80 – 120 hp, some were fitted with Subaru car engine conversions, one was fitted with the Wilksh diesel and one (taildragger I believe) has been fitted with a UL engine.
For what it’s worth, my Mono XS without any speed kit, fixed pitch Warp Drive prop and Rotax 100 hp engine will easily do 120 knots at 5000 rpm, about 135 kts flat out, but I usually cruise at 4800 rpm at 112 kts burning around 15 litres/hr. Mine lives on a 400 m grass strip and climbs at 1000 ft/min at MAUW.
FWIW I know the person who did the flight testing on the Flyer Mod Europa tail dragger, he owns a mono XS and recons the taildragger was bout 3 kts faster. This was some time ago and I don’t know if it was fitted with spats, has a VP prop, eng hp etc. I would suspect that there isn’t much speed difference between mono and taildragger but an obvious weight and speed difference between mono and Tri.
I can also add that Miles is my inspector, he flew the prototype Europa which originally had separate levers for u/carriage and flaps. He lowered the u/carriage in the cruise and saw no speed change!
The Europa owners club is great, further info from here https://www.theeuropaclub.org/
Rob P, G-BLEW, BobD liked this
By Rob P
#1851475
Thanks for that @Volare
The Tri-gear Van's is a little slower than its equivalent proper model. The retract was about the same difference faster, 3kt if memory serves.
It does make you wonder why anybody would bother with the complication and expense of retracts
Except... They do look better :D
By Alt
#1851495
The main point you are missing is that with the mono the main wheel is a much larger diameter that either the tail dragged or the tri-gear making it much more suited to farm strips etc as the larger diameter gives less rolling resistance on soft ground or longer grass. I have built two classic Europa’s, one mono and one tri-gear both had 912S and speed kits, they weighed within 1lb of each other and you would be hard pressed to tell any difference between them in flight other than the tri-gear felt slightly less agile in roll, probably due to the increased pendulum stability of the three still legs hanging down. The mono was definitely better when the grass was longer or the ground was soft and the tri-gear much easier on hard surfaces.
Both are lovely aircraft offering superb, visibility and handling. They are very stable for cruising and if built correctly have a good payload. They both offer excellent performance and are very efficient. The mono is a bit more tricky to handle on the ground, but with a proper training it is very manageable. The tri-gear is very standard but proper training is still recommended. The tail wheel will give you something in between. It really depends what you want to use them for.
As a final thought, in my experience and I have inspected many, the biggest factor is the basic weight, the lower the better and there is a huge variation between aircraft depending on how they have been built and how much ‘kit’ they have fitted. If you are thinking g of buying one, do some weight and balance calculations using the actual figures for the aircraft to see what you can actually carry.
G-JWTP liked this
By PA28
#1851497
I have flown all the Europa models except the motor glider. The tail wheel (swiss mod?) Version was my favourite. I recall it was less than 5kts slower than the XS mono with a 912S and vp prop.
There was a fixed gear version of the silence twister that had almost identical cruise speed to the RG version.
Rob P liked this
By Rob P
#1851504
Thanks @PA28
As I stressed at the start I'm not remotely in the market, I was just interested in the performance difference between fixed tailwheel and retract variants of 'the same' airframe.
Up to today I hadn't realised that a taildragger Europa was a thing.
