Sat Feb 20, 2021 8:36 am
#1827709
Sooty25 wrote:So, did anyone actually get prosecuted over this?
The CAA for their seemingly laissez-faire approach perhaps?
Stampe wrote:...what is most probably the most serious airspace infringement ever in this country...
Shoestring Flyer wrote:Do we know if any heads have rolled at the CAA over this dangerous fiasco?
Morten wrote:By sheer coincidence, this one popped up on my linkedin feed... monkeying around with UAVs
Sooty25 wrote:something has just occurred to me. This Airspeeder was a scaled down prototype version of the intended aircraft. The final design is a manned aircraft for racing. If they had built a full sized prototype, it would presumably have had a pilot, so would have needed I'm guessing.... CofA? Unless they produce them as a sub 51% kit, then a PtF? but what does a multirotor kit aircraft come under?
Whatever the real thing would have been, it would have been pilot controlled, inspected by a third party and presumably fitted with an on board isolator and BRS.
If they'd have gone 100%, this would never have happened.
Genghis the Engineer wrote:Any post flight test manned aircraft in the UK, and most other European countries, needs a CofA or PtF - that isn't open to negotiation.
NigelC wrote:... above a certain weight, not sure what that weight should be but I would suggest 95kgs is above it.
