By Anon - Fri Feb 12, 2021 1:25 pm
#1826254
I've been meaning to post this for a while, but it's only now I feel it's relevant to do so.
Not so long ago, I passed my NPPL GST in the C42, which - as many will know - is a fabulous little aircraft with some design quirks compared to others. One of those is that the throttle is located between the pilot's legs, requiring a deft bit of multi-tasking as you steer with the centre-mounted control stick and manage throttle with your left hand between your knees.
I was - and remain - a very conscientious, careful pilot and I am thoughtful, deliberate and methodical with my pre-flight checks, always paying close attention to the things that matter. On what was my first flight with a passenger after getting my licence, things were no different.
On this flight, I was accompanied in the RHS by a good, childhood friend who flies proper planes for a job. I'd explained to him that the C42 was small and that weight was at a premium, so dress and pack light. He arrived at Shoreham on the day of the flight duly trimmed down, but carrying a lightweight rucksack in which he'd got his wallet and a few bits.
After completing our briefing and checks, I taxied us out to the holding point for Runway 02 and obtained our takeoff clearance. From there, line up, throttle open and away we went.
Now, at this point I'd just passed my test and in total had 31 hours of time in the aircraft. So, as a means of excusing what follows, I'd like to say that nothing felt untowards, except perhaps the takeoff roll was a little bit slow. In my head I'd mentally prepared myself for this: it's a microlight with two gents in it, nearing the maximum MTOW limits, compared to recent flying on my own or with a smaller instructor. We got airborne, but then struggled to climb.
Looking at the engine RPM, things looked a bit slow - and I could see we really weren't gained much height. I wouldn't say that panic set in, but maybe some concern. If I'm honest, in my head I started thinking about YouTube videos I'd seen (and I think a couple will pop to mind!) of aircraft struggling to climb out and how things ended badly for them. I lowered the nose and managed to maintain height while the aircraft struggled to accelerate just a few hundred feet as the end of the runway passed below us.
I gave the throttle a hard push forward....and that's when I realised what had happened.
After my pre-flight checks, my friend had inadvertently popped his rucksack down in front of him, between his knees, without thinking anything of it. And in my pre-flight checks, although I'd checked for free and full movement of all control inputs, including the throttle, I hadn't thought to brief him NOT to put anything in that space due to the potential restriction of the throttle. When I lined up, I didn't look over to his side, but I could see that my throttle was clear between my legs and so my brain subconsciously said to me: 'all is good'.
In total, the whole thing probably lasted 15 - 20 seconds. Once I realised what had happened, I promptly told him to put his backback on his lap and once he did, suddenly I realised how restricted the throttle had been; I pushed it forward, suddently got a surge in power and began to climb away.
On this occasion, although there was a bit of drama, there was no harm done, but things could have so easily ended badly.
Lessons to be learned:
[list=]Think about WHY we have each pre-flight check, not just 'WHAT' each pre-flight check is. If I had taken some time prior to the flight to think about this, I would recognise that there is a risk in a passenger impeding the throttle accidentally and so I should have checked there was nothing in the way on their side, as much as I check mine
It sounds so blindingly obvious, but there's almost a blind assumption that 'full and free movement' applies only to the control surfaces rather than the throttle, which is such a schoolboy error to make*
Make sure you are aware of the gotchas in your aircraft and brief your passenger about them; don't assume that they know how to behave correctly (as an innocent mistake can testify)
[/list]
Finally, as controversial as this might sound, I actually think this is one of those examples where watching YouTube is really good for you. The videos I was thinking of (which you'll easily find, I think one is on FlightChops) are a good way of dealing with issues by proxy; it's actually quite refreshing to see someone else make a mistake, because you can learn from it vicariously. In this situation, I felt like I was more aware of the aircraft not climbing out correctly not because I was experiencing it directly, but because I'd seen other pilots struggling in that situation.
*I might be totally wrong, but actually looking at my checklist, I don't think there is an item for checking that the throttle is clear with free movement; it's implied as part of the controls full and free check. There are multiple checks that the throttle is set, or as part of the mag checks, but nothing after the passenger gets in - and nothing to check that the throttle can open fully.
[/list]
