Cardinal Sin wrote:You’re on a premises which is supposed to have carried out a risk assessment and put mitigation procedures in place, like the QR code check in etc. That’s why it’s different from “mixing” indoors with friends. .
Ah right, that'll be one of those places with arrows on the floor, that usually end up pointing you at an exit door that was an entry door...but still has the "no exit" sign on your side... so you then ignore the arrows and wander over to the original exit with the big sign saying "exit", which is now an entry...
Of course none of this really matters because there are only a few of you there anyway, but just as you find a door that is open, someone will hurry up to you and ask why you are not following the arrows clearly marked on the...
Regards, SD..
PS. Ive always hated IKEA too..
Its generally best to make a hole in the sky.......not the ground...
