Sat Aug 01, 2020 10:41 am
#1787623
I'm having dual G5 fit done shorly to replace the vacuum AH and DI/HSI, the setup requires the use of a GPS antenna feeding into the AH, so is it possible/practical to use the RS232 output to feed the TT31? bearing in mind it already feeds into the HSI. Not much info in the Garmin install manual about this. Any advise appreciated.
