Bill McCarthy wrote:Sounds like a good way for setting yourself for a groundloop, especially in a Jodel.
Why? do Jodels have tendency to turn while they fly/roll in forward sideslips?
If you keep straight line (looking at runway end in Jodels/Cubs or above to clouds in the Pitts) there is simply no way you will ground loop, but will ground loop when turning (may have to add that forward sideslips are NOT turns, neither in the air nor the ground)
Crash one wrote:How do you ground roll while sideslipping? Perhaps on very wet grass?
Bouncing should not be a problem on soft grass, the real problem is getting stuck !
But I agree, surely I would would not sideslip the ground roll on takeoff or landing with soft grass, as you said first you don't want more weight on both wheels and surely I don't want one going down while the other is not, but at the end of the day one should use sideslip as tool, it is way more adequate than dynamically fiddling with power/pitch/flaps* but yes it comes with few risks
*On flaps some "very experienced" people do fiddle with them: some land by raising them, some raise them while rolling after landing, some lower them while rolling on rotation, some raise them in ground effect, wise pilots tend to set them in one place and forget about them
