Mon Jun 04, 2018 11:48 am
#1658537
R46C Is part of the military low flying sysem and goes from 800'agl to 3400'agl it will only be active by NOTAM and only when aircraft are flying along it. Usually for 10-15mins of either side of the planned movement. The FIS will give you a transit if they can if you are unlucky enough to arrive at the small time slot they are active and for some reason can't go over it. They are usually quiet mid morning until late afternoon and in the evenings and weekends.
Wave if you're passing!!!!
