Fri Jun 29, 2018 8:54 am
#1621359
A question for the illuminati ....
If I type GCDMV into the FR24 search box it returns two aircraft , an RV and an SKRA. .
I know one of the aircraft and have seen his transponder and on the front panel it displays the Registration it is programmed with - but they both appear to have the hex I.D 404E51 on FR24, however G-Info shows the Hex as 404E18 for MN and 404E51 for MV.
Is it likely that MN has coded the wrong Hex Id despite programing the correct Reg ?
Does FR24 work on both reg and hex ?
Enjoy everything - Life is Short.
