Thu Feb 07, 2013 5:29 pm
#1143762
I am recently qualified for my PPL and am now thoroughly enjoying my flying. My usual steed is a 152 or Pa 28 Warrior. On one of my final dual 152 flights before qualifying we flew into Southend for a tour around the control tower and to spend time with ATC. All went well with an enjoyable forty minutes or so watching comings and goings. Pre flight checks completed we lined up on the easterly heading and took off. Shortly after and less then a minute into the climb I mentioned to my instructor that I felt the climb rate was poor compared to usual. ATC then came on asking if all was ok as from the tower we looked quite low compared to the normal climb rate they view from their elevated perch! A quick panel scan T's & P's where they should be, primer locked, odd! Mags have you checked the mags said my instructor!! Sure enough on doing the engine run up and mag check muggins here had somehow not switched back to right, we were running on just the left mag. Turning the key one notch to the right had the instant desired effect, normal climb rate was resumed.
I felt a fool, I had never done this before and wondered to myself would I have found the problem on my own? It goes to show how easily a little lack of concentration or distraction can cause a potential
incident, pretty sure it was the Easyjet heavy that departed before us that took my attention away from completing this vital check correctly, that's no excuse I know.
Certainly plenty of attention paid now to mags. One can never over check, but you can regret not over checking!!
Tango Charlie
