Sun Mar 27, 2022 1:40 pm
#1905286
2019 AERA 796 for sale with databases to end of year.
Pictures here: https://www.facebook.com/marketplace/item/393558715502462/
In perfect condition, sold with:
SD card and significant databases (most with remaining updates until December 2022). See picture for details.
Latest software updates.
RAM mount with Yoke attachment.
Inbuilt power and data cabling, for audio output and auto-pilot management if desired.
Homemade protection pouch – not beautiful, but it works (with aluminium screen protection plate).
This is the 796 version (better than 795).
Has done a great job for me, flying all over the world – but I now have full glass so no longer needed.
Can be sent anywhere in the world at cost, or collected from either Brussels, London, Chicago or LA.
GBP1500/1800EUR new value without databases.
ASKING £750 or 900EUR or $1000.
• 7" diagonal, touchscreen aviation portable GPS with XM WX Satellite Weather & Radio (not designed for automotive)
• Same as the aera 795 with the addition of XM capabilities
• 3D navigation, advanced electronic flight bag capabilities
• Virtual 3D behind-the-aircraft perspective of surrounding terrain derived from GPS and the on board terrain database
• High-definition, sunlight-readable display
• Works in both portrait and landscape mode
• Optimized design to fit on the yoke or use as a knee-mounted device
• 4 touch keys on bezel: back, menu, direct-to and nearest for quick navigation
• All other functions are accessed through intuitive on screen icons with labels
• Quickly pan across the map screen & pinch to zoom
• Fulfills the role of either a Class I or Class II electronic flight bag
• Initial georeferenced VFR sectional & IRF enroute charts come preloaded
• IFR mode displays victor airways, jet routes, minimum enroute altitudes and leg distance
• FliteCharts provide approach charts and airport diagrams for the US, while pilots who prefer Jeppesen can use optional ChartView services
• Document viewer
• Scratch Pad feature
• Checklist Viewer - allows for customized and interactive electronic checklists
• Enhanced situation awareness with 3D mode, and top-down view of your entire route
• SafeTaxi provides detailed taxiway diagrams and position information for over 1000 US airports
• Private airport and heliport database expands emergency "nearest" options
• FBO, ground transportation, lodging and other facility information for most US airports are available through preloaded AOPA airport directory data
• International pilots may choose to global AC-U-KWIK airport directory data instead
• GXM 40 smart antenna is included, giving access to high-resolution weather and audio entertainment (XM subscription required)
• XM WX includes next generation radar (NEXRAD), aviation routine weather reports (METARS), terminal aerodrome forecasts (TAFs), temporary flight restrictions (TFRs), lightning, winds aloft and more for the US and Canada
• Can receive PIREPs, turbulence forecasts, icing forecasts and more
• Weather data can be laid directly over the unit's navigation and topographic map databases
• Plus 170+ channels of digital music, news & programming through your aircraft headset or cabin audio system
• 2 serial ports
• Allows for simultaneous connectivity with other hardware
• Optional Garmin GTX 330 Mode S Transponder interface to access TIS alerts, where available, on the device
• Optional Garmin SL30/40 radio is also compatible
• Includes SD card slot for easy updates and expansions
• Features include:moving map, panel page, HSI (GPS-based), IFR map mode, TIS alerts compatible, Audible Terrain alerts, standard Terrain resolution, Smart Airspace feature, Automatic logbook, and Separate serial and USB interfaces
• Document viewer
• 2 serial ports
www.vintageairrally.com
