A place for regular members to sell their aviation stuff (non-commercial only pls, and no aircraft for sale)
Forum rules: Non-Aviation or commercial items are not accepted. The option to put items for sale here is in the first place for regular posters, if you are not (yet) a regular poster it may be that your ad will not be accepted.
Buyers and sellers should be aware that Flyer Forums or its parent company are not responsible for the articles put up for sale here nor can be held liable for any part of the transaction process - the usual internet buying and selling caveats apply and should be borne in mind when dealing with buyer/sellers through an internet site.
#1692570
RFD Pilot liferaft; 4-6 person; covered with survival equipment inside. (Unused, of course.)
(Selling it as lost my medical and sold my airplane.)
The same liferaft is for sale on Transair at £1,595. Reasonable offers accepted.
Tom Dove
tomdove@hotmail.com
07771 560 799
I am based in north-west Bristol.
Details:
The Pilot is a square shaped liferaft which is manufactured from fluorescent yellow polyurethane coated nylon with improved flame retardancy. The canopy is an integral part of the raft, and is automatically erected and supported in position by an inflatable arch tube. The Arch tube also acts as another buoyancy compartment, in addition to the primary buoyancy tube being designed with a non-return CO2 valve. The entrance to the raft can be sealed with velcro to enclose the occupants from the elements. The Pilot liferaft features stabilising water pockets fitted to the underside of the floor to prevent capsize in rough water, and a boarding anchor is fitted at the entrance. The liferaft is fully equipped with internal and external lifelines, a rescue line and quoit, a sea anchor drogue and an internally stowed emergency pack positioned under the boarding ladder for immediate use. The Pilot liferaft is packed in a flexible valise which is held closed with a velcro fastening. A gas cylinder cord is stowed under a flat pocket on one side of the valise. The RFD Pilot is a British made product.
Designed and build to survive the cold waters of Europe.
Standard Equipment Includes: Top-up pump, Bailer, Hand-Flares, Paddle, Signal Mirror, Leak stoppers, Sea Anchor, Safety Knife, Rescue line and Quoit
Additional Features Include:- Standard equipment package (see listing), external lifelines, Hand Flare, sea anchor, approved single cylinder inflation system and large capacity water pockets for high stability.(The pilot raft has 3 water pockets attached to the underside of the floor positioned at 90 degrees to each other and then at the 4th position the cylinder is positioned and provides a degree of ballast as well.) The RFD Pilot is a British made product of the highest standard.
Technical Details - Pilot liferaft:
Packed Dimensions: 30 x 60 x 15cms
Inflated Dimensions: 1.875 x 1.875 x 1.0 m
Weight in Valise: 12Kg
