Sun Nov 10, 2013 1:16 am
#1221653
Regarding air to air and 123.45...
AIC: Y 133/2012 04-OCT-2012
USE OF FREQUENCY 123.45 MHz IN THE UK
Cancels AIC Y 044/2010 (this was the original announcement, very similar to this AIC)
1 Introduction
1.1 ICAO Annex 10 (Aeronautical Telecommunications) Volume 5 designates frequency 123.45 MHz for use as a VHF air-to-air
communications channel to enable aircraft engaged in flights over remote and oceanic areas out of range of VHF ground stations to exchange necessary operational information and facilitate the resolution of operational problems.
1.2 This Circular is issued to remind pilots that use of the air-to-air channel can cause interference to and from aircraft using the same frequency for air-ground communications, and that pilots should adhere to the published procedures for the frequency.
2 Procedures
2.1 Procedures for the use of 123.45 MHz are as follows:
a. In remote and oceanic areas out of range of VHF ground stations, the air-to-air VHF communications channel on frequency 123.45 MHz shall only be used by aircraft fitted with communication equipment meeting the characteristics described in Annex 10 Vol 3, Part 2 Chapter 2. Amongst other requirements the aircraft radio must be capable of 25 kHz channel spacing.
b. Pilots shall only use frequency 123.45 MHz for the exchange of operational information and to facilitate the resolution of operational problems.
c. Pilots shall establish air-to-air communications on frequency 123.45 MHz by either a directed call to a specific aircraft or a general call, using the RTF phraseology shown at Annex A.
d. Pilots using 123.45 MHz as an air-to-air communication channel shall ensure that adequate watch is maintained on designated ATS frequencies, any other mandated frequencies and, where required by company operating procedures, the frequency of the aeronautical emergency channel.
Phraseology for use on Frequency 123.45 MHz
1 As an aircraft may be maintaining watch on more than one frequency, the initial call should include the identification ‘Interpilot’.
2 For use when making a directed call to a specific aircraft:
‘(Callsign of aircraft being called) (Callsign of calling aircraft) interpilot, do you read.’
3 For use when making a general call:
‘Any aircraft vicinity of (specific position) (callsign of calling aircraft) interpilot (any additional appropriate information).’
