Irv Lee wrote:Have you checked the exemption? If it says it is ok if other authority agrees, Mr I. O. M. CAA-equivalent was all in favour last time we spoke but I suppose should ask again.
I forgot to ask... easa licence, easa aircraft???
Just checked. The exemption for easa licences in EASA aircraft (which you ought to have a copy to hand if you are using it) says the combination is valid amongst other things:
b) within the United Kingdom; or
c) with the permission of the relevant authority, within a Crown Dependency, but for an A to A flight only;
So the combination does not at first pass seem valid for mainland to IoM with easa stuff
Irv Lee - (R/T & Flight Examiner)
Deconfusion & Preflight Aide-Memoire:
http://tinyurl.com/pilotpalUK GA Twittering not Tw@ering: @irvleeuk
