Major logbook correction
PostPosted:Thu Jul 04, 2019 6:16 pm
by pilotamx
Hi,
I have recently moved all my logbook onto a software and excel. I've found some errors, particularly with number of landings and times. Actually errors are old, like at page 30, I counted 7 landings instead of 15 and this error has been moved over until today. Same happened for timings in the past.
What should I do? It is not matter of reclaiming few landings and hours which are actually than what I've in my logbook; the accuracy is bad. If I go back and make the connection, I need to correct all pages and this, whilst doable, seems not a _good_ approach. Is there any other option?
thanks
S
Re: Major logbook correction
PostPosted:Thu Jul 04, 2019 6:32 pm
by Miscellaneous
Depending on significance I would either leave it or amend the current page total whilst adding a note to that page.
PostPosted:Thu Jul 04, 2019 6:36 pm
by Kemble Pitts
Maybe add a new line in your log book which applies the delta (correction). Put a comment in that explains where the data has come from so that you and anybody else can trace the details, should anybody really want to.
For example 6 hrs in the P1 column with a comment that they were missed on 10 Jan 2017 or something like it.
Total that page up and then the next page will be starting 'all square'.
PostPosted:Thu Jul 04, 2019 6:51 pm
by pilotamx
Miscellaneous wrote:Depending on significance I would either leave it or amend the current page total whilst adding a note to that page.
Cool, I've considered this initially. I was not sure it was a correct and accept approach from EASA standpoint.
PostPosted:Thu Jul 04, 2019 6:53 pm
by pilotamx
Kemble Pitts wrote:Maybe add a new line in your log book which applies the delta (correction). Put a comment in that explains where the data has come from so that you and anybody else can trace the details, should anybody really want to.
Thanks. I am actually seeing more than one error. I guess amend totals at the end of current page and then start from the next one with _correct_ ones is works better.
Thanks
PostPosted:Thu Jul 04, 2019 7:00 pm
by Miscellaneous
pilotamx wrote:
Miscellaneous wrote:I was not sure it was a correct and accept approach from EASA standpoint.
Nor am I, it's just what I would do. :D
PostPosted:Thu Jul 04, 2019 7:57 pm
by Kemble Pitts
Nobody (EASA) can complain if you are making the totals correct.
PostPosted:Thu Jul 04, 2019 9:53 pm
by Genghis the Engineer
Thanks
Pretty much what I did when with 1000hrs or so I transferred to an electronic logbook - it found various arithmetic errors.
I put a line saying something like "Revised totals below due to recalculation in electronic logbook" and then inserted the new totals.
Various examiners have seen my logbook since, none have even asked about it. Since then, CAA only get a printout of the electronic logbook anyhow as half the point of it was to avoid ever having to consign my paper logbooks to the post again.
PostPosted:Thu Jul 04, 2019 10:11 pm
by seanxair
I do about 15 hours a year and regularly balls up the count from line to line. I embarass myself by my ineptitude to count in 60's :oops:
PostPosted:Thu Jul 04, 2019 10:14 pm
by Miscellaneous
@seanxair I have a suggestion to resolve you poor arithmetic…fly more often! :wink:
PostPosted:Fri Jul 05, 2019 5:03 am
by seanxair
Miscellaneous wrote:@seanxair I have a suggestion to resolve you poor arithmetic…fly more often! :wink:
Wish I could! I do a lot of 20-30 min local stuff so fairly current. Just hard to get away for longer with family stuff going on :(
PostPosted:Fri Jul 05, 2019 7:37 am
by allout
We all make mistakes from time to time, pilotamx.
At my last (regional) airline, running totals of of aircraft time were entered in the tech log by pilots, flight by flight.
Lots of scope for errors, but a great deal hangs on those totals, so corrections were far from unknown.
