Ian Hibbert wrote:Iceman - I believe it was 250 PI as opposed to total time,for anyone getting out the calculator.
Ian, you are absolutely right.
250 hours P1 required for all pilots, as confimed by the
airfield plate.
Rich T, when I've been there in the past, it has been customary to make the short hop to Dijon Longovic on departure to refuel, file flight plans, customs & immigration, etc. You won't have any problems getting in 4-up but should it be a bit tight getting out (it's 1125 ft elevation and can be hot), there will be aircraft available to get you over to Longovic where you can comfortably take off 4-up. On the two occasions that I've been to the Château, I've been 3-up in a turbocharged Arrow so it wasn't an issue but I believe that other forumites have witnessed some 'interesting' performance-related departures from the strip.
Iceman
You are still dangerous! You can be my wingman
anytime.
