Having never been, this is high on my agenda.
However I don't have an IR so wx could quite likely be an issue.
jerry_atrick wrote:I can still use a whiz wheel if required....
Irv Lee wrote:jerry_atrick wrote:I can still use a whiz wheel if required....
You will be beating them off with a certain sort of stick if it's still icy mornings then, you can scrape ice off with the plastic part.
