226
You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves (see Rule 236).
226
nickwilcock wrote:From the Highway Code:but you MUST switch them off when visibility improves.
Rob P wrote:And don't get me started on the use of fog lights at the same time as headlights.
skydriller wrote:Presumably you are talking about full beam headlights...which is pointless in fog. But I dont think its possible on most cars to turn on just foglights...certainly not on my GFs beemer, you have to have the main lights on first
PeteSpencer wrote:In deepest Suffolk, front foglights are most useful for their 'side-spread' in illuminating the nearside kerb with its untreated, rim-smashing potholes in these days of zero road maintenance, absence of nearside whitelines and cr ap modern mud-obscured so-called 'cats eyes'.................
Flyin'Dutch' wrote:Bløødy Dutch, come over here, steal our jobs, marry our wimmin, bugger off, and still make UK law!
What, my friends, what, have the Dutch ever done for us!?
malcolmfrost wrote:Which is why cyclists need to be a reasonable distance from the kerb and may need to swerve to avoid one which explains 1.5m clearance
-DV8R- wrote:Flyin'Dutch' wrote:Bløødy Dutch, come over here, steal our jobs, marry our wimmin, bugger off, and still make UK law!
You lot invited William (of Mary fame). That's how the Dutch came to be here. By the way, we ruled the waves before you did....
Sooty25 wrote:Dutch Reach - useful in a panel van!
Miscellaneous wrote:malcolmfrost wrote:Which is why cyclists need to be a reasonable distance from the kerb and may need to swerve to avoid one which explains 1.5m clearance
My recollection from when I sat my car test (it wasn't yesterday) was the distance a cyclist should be passed at should be sufficient, that should he fall off in to the road one would not make contact.
Maybe the condition of the roads was better then?
