Wed Nov 10, 2021 2:58 pm
#1881769
lobstaboy wrote:Rob P wrote:... does not involve rubber gloves or lubricant.
Spoil sport!
@flyingearly another thought - does the urge to pee fade a bit once the aircraft is on the ground, or are you leaping out and having to pee next to the tailplane on the grass?
As you say, it's probably your mind playing tricks.
The urge to pee is sufficient that when I'm on the ground, I'll hunt the loo out first before coming back to put the aircraft to bed. Not quite peeing on the tailplane, but my prioritisation is urination (as they say).
Incidentally, I've just read that male urine keeps badgers away from your (literal) vegetables, which is a handy tip if you like to grow sweetcorn (like I do).
