Fri Dec 04, 2020 10:45 pm
#1812635
akg1486 wrote:Charles Hunt wrote:I will never get rocketry. I can't comprehend that you can control the thrust so accurately that the whole thing doesn't immediately topple and go out of control, like trying to balance a pencil on your finger and push it up towards the ceiling, and then to bring it back to earth again so it lands like the aforementioned pencil (well OK some Xmas tree stand legs came out) is just mind boggling.
Well, it's literally "rocket science".
Actually... that is a false comparison. The problem with balancing a pencil or broomstick on your finger is that your finger pushes *upwards*, not towards the CG of the broomstick. As the broomstick topples, you need to adjust your push.
The engine at the bottom of a launcher is, for most intents and purposes, fixed, and always pushing through the CG. Any small offset will remain a small offset - as opposed to your finger where any offset dynamically increases.
In reality, most engines (but by no means all) will have a very small one or two axis gimballing range and they are controlling the thrust orientation, and it is indeed rocket science, but the pencil/broomstick comparison is false.
We all live under the same sky, but we don't all have the same horizon.
