  • 9
  • 10
#1772917
Pm sent
The most critical dimension is the height from the top of the ‘dome’ to rim of 65 mm int dia down pipe the plug rests in = 20mm.
Many thanks
By Colonel Panic
#1773333
@PeteSpencer - I sent your widgets first class on Friday, so hopefully will arrive on Monday.
Meanwhile, quite chuffed with this home grown design and build - to attach an Apple TV on to the VESA mount behind the TV. I've already bagged the first prize of a Haribo for spotting the deliberate mistake - but am sure a Dremel will make access to the power port easy :oops:
eltonioni liked this
#1773351
Great stuff mon colonel, thank you very much.
Only one more lockdown project left now (#8 ) and I'll be twiddling my thumbs..................
Ring doorbell installation/power wiring completed today with much wire-threading/pulling through small holes.....
Peter :wink:
Colonel Panic liked this
#1773713
Colonel Panic wrote:@PeteSpencer - I sent your widgets first class on Friday, so hopefully will arrive on Monday
Received today mon Colonel with many thanks : A perfect fit as images show the cap doing the job intended just prior to swinging the pipe into place under cabinet
Them printers are brill. Will be sealing in into place with silicone goo late
Grateful thanks to developer and manufacturer
Peter aka v happy bunny :thumleft:
kanga, Flyin'Dutch' liked this
By Colonel Panic
#1773716
Excellent - well posh. Did the lip on the under side of the dome fit around the pipe too, or did that late design change not work?
#1773719
Colonel Panic wrote:Excellent - well posh. Did the lip on the under side of the dome fit around the pipe too, or did that late design change not work?
Side overhang lip fitted perfectly ! Would be well waterproof but as I’m sealing the two halves anyway I’ll bung some sealant all around plug .
I took another image but while my usual trick got the first two images upright I just couldn’t get the third off its side
I’ll post final image when cap is sealed in, pipe swung back under cabinet and hole back filled
Many thanks again. I've pm’d you ref costs
Peter :wink:
By Colonel Panic
#1774157
Another day, another commission. I should go in to business.
A virtual Haribo for the first correct guess at what it is. FWIW there is a hole right down through the centre, and the two halves screw together.
Amazing what first world problems require a solution ...
#1777311
Now that common sense has returned I attach the promised pic of the Slup/Col P cap in situ
It’s a bit smeary cos of residual clear mastic but it’s hidden behind buddleia and the pigeons have aleady christened the cabinet ++
kanga liked this
By stevelup
#1777316
This thread ended up costing me money...
It prompted me to bring my old printer back to life but it was beyond treatment and I had no choice other than to put it out of it's misery.
I've now got a shiny new Ender 3 Pro with BLtouch probe, and finally, after all these years, it has a dedicated place to live (which I had to install a power supply and supplemental lighting to!)
Dave W, Colonel Panic liked this
#1777339
stevelup wrote:This thread ended up costing me money...
Holy poo! what a gadget:
How does the raw material come? In sacks of granules or is it some kind of liquid like a standard printer?
By JonathanB
#1777346
PeteSpencer wrote:How does the raw material come? In sacks of granules or is it some kind of liquid like a standard printer?
On a spool - that is it on the top of the machine.
PeteSpencer liked this
By mmcp42
#1777402
I got the same - a basic Ender 3
hav installed glass plate and Capricorn Bowden tube (better heat resistance and slipperyer (is that a word?)
busy printing parts for an enclosure to keep it in :)
By mmcp42
#1777403
I'm "driving" it with OctoPrint running on pi
stunning piece of software
I also separated the x-axis cable from the Bowden tube, puts less of a load on the tube
Dave W liked this
  • 9
  • 10
