Colonel Panic wrote:stevelup wrote:2) RAID is not a backup
Is that because of the way it was configured (RAID 0 / RAID 1 etc), or because a single point of failure failed, or something else?
You need different types of backup, depending on what type of failure you want to protect against. In the bad old days, the most likely failure was the spinning rust, so simple disk mirroring was an easy win. But, as has been observed, that doesn't protect you from a rogue power supply frying both disks, or the building burning down. For that, you need to copy the data somewhere else. But even that doesn't protect you against corruption of the underlying data (hence multiple copies)... So, you may need more than one backup mechanism, depending on the risks you are trying to protect against. "As I said: it depends..."
