Re: Forum images
PostPosted:Sat Dec 29, 2018 8:57 am
by Mike Tango
If number 2 is as simple as changing to point to a different DNS server then it’s a 30 second job if you’re otherwise happy with keeping Vodafone.
Re: Forum images
PostPosted:Sat Dec 29, 2018 10:57 am
by Cessna to the sky!
Had this exact problem when changed to Vodaphone last month, changed the DNS settings and now all OK.
Re: Forum images
PostPosted:Sat Dec 29, 2018 11:09 am
by TheKentishFledgling
Cessna to the sky! wrote:Had this exact problem when changed to Vodaphone last month, changed the DNS settings and now all OK.
In reality it probably won't make a difference to you as an end user, but as good practice you should change either the primary or secondary server to 8.8.4.4 rather than having both the same.
Re: Forum images
PostPosted:Sat Dec 29, 2018 12:40 pm
by Colonel Panic
I recently moved from Google's all-seeing 8.8.8.8 to 1.1.1.1 - see
viewtopic.php?f=6&t=110045&p=1645599&hilit=dns+server#p1645599
