Sat Aug 18, 2018 6:58 pm
#1632124
Our U/v high voltage fly zapper has packed up only 1 year old: The suppliers have replaced it promptly F o C, but I have traced to problem to the ballast firing the 2 x 15W T8 18inch u/v tubes and I think it is repairable.
Everything else works, the rf switch fires the 2kv grid, both starters are OK, but the bulbs don't light.
The day before one of the bulbs was flickering so I replaced it but no joy.
Trouble is I can't find a compact ballast (120 x50 x 40 mm) which will fit in the casing: they're all 200mm + long.
Does anyone know where I can get a compact ballast 30W total firing 2 x 15 w blacklight u/v tubes?
Any advice would be gratefully received, particularly how critical is the wattage?
In particular would a 30 watt unit be OK for 2 x 15 watt tubes even though the spec says I lamp.
For what its worth the Ballast is a 'Gleeson Ballast GL 30' and made in China:
Googling and comprehensive search fails to reveal suitable unit, or if I find the right size its boarded for one lamp only.
It's not a big deal, I could easily bin it but repairing it would be a challenge particularly as they retail at £60 on Amazon.
TIA
TIA
Pete S as was
‘Work in progress’.
‘Work in progress’.
