Wed Aug 21, 2019 3:26 pm
#1714697
Zoe's battery management system means there is no danger to the batteries in charging to full every time (I know that isn't the case with other cars, where you're recommend to only top up to full when the range is needed).
In many cars, as batteries reach capacity, the charging power will be reduced to protect the batteries. Balancing tends to happen in the last 1 or 2 % of charging. If you don't need full capacity, there is probably no need to balance, so stop the charge at 98%. If you let it go to 100% each time, balancing should take almost no time. If you only go to 100% a few times a year, balancing could take a considerable amount of time. Each car has different "tailing off" thresholds and it may be based on other factors, such as how warm the batteries are getting, so there is no hard and fast rule for when to stop charging for max-efficiency. It will matter more to different cars than others.
