Fri May 04, 2018 11:47 am
#1609670
We really need our 36Volt electric golf buggy to shift one ton of fully fuelled Arrow on wet grass,
Yesterday a member had a problem with a loose battery terminal which caused arcing and virtually destroyed the lead negative terminal post of one of the batteries.
The buggy is powered by 6 no. 6Volt 235 A/H Deep cycle lead acid batteries (36 volts total) in series and the affected one is in the middle of the series string. I was able to stabilise the terminal to stop movement/further arcing with a bodge of a coupla plasterboard screws to allow me to drive the buggy back into the hanger but the affected terminal post looks like a chewed apple core and I doubt will take full current of a loaded motor.
So I have a coupla questions please for the cognoscenti on here:
1)Can battery posts be repaired? I guess not.
2) I can't find the exact make online but I can find same capacity, so would putting a new battery in with five old ones cause a problem? New prices are £160-180 so we can't afford to replace the lot (£1k) particularly as the old batteries still work well, but there is a feeling that a new battery might cause bigger problems.I did think about isolating the dud battery and running it off five (30volts) but I don't think it would have the power.
At present I'm getting quotes from a local golf buggy repair shop for a new battery plus safety check (he won't service it as he doesn't do that make an its ancient).
I'd greatly appreciate your views: At the present I guess we're looking at replacing the battery ourselves and giving the buggy a grease up and clean but I don't want to wreck the other batteries.
BR and thanks.
BR and thanks.
Pete S as was
‘Work in progress’.
‘Work in progress’.
