Thu Jul 27, 2017 5:47 pm
#1549163
In the good old days most campsites were occupied by caravans. These days I would say that maybe 50 or 60% are campervan or motorhomes.
At the moment, other than a daily commute, EV still doesn't make sense for me.
nallen wrote:even some of the remoter corners of the British Isles seem to have a decent quota.
Lindsayp wrote:Since Macron committed France to the same target (before the UK govt said it) I presume the charging points will exist in France as they will in the UK by 2040
romille wrote:OCB wrote:Drag isn't going to be a large component. I suspect weight is though! How much does a draggy tin house on wheels "all-up" weigh?
Most are rated between about 1 to 1.3 tons, but if you start to load them with additional batteries, goodness knows. You also need to bear in mind that the towing car will probably also be heavily loaded.
mattmoxon wrote:I climb into my Mustang on a morning and fire it up, there is the initial bark as the cold start flares the rpm to about 1800, this settles down quickly to a fast idle as the engine clears the excess fuel and then once in gear 650rpm where it emits a wonderful off beat bassy thrum (think old motorboat), you can feel it all the way through the car, the steering, the seat of your pants, it feels alive.
avtur3 wrote:[I think you'll find caravan weights have been moving upwards in recent years...
