#2027053
I thought I'd join in and add my own, rather lengthy, PPL journey. If you get bored easily, then skip to a more interesting post!
I wanted to write something to encourage others who may feel they have slightly higher hours, struggling with one area in particular, or even thinking of giving up. (I've been there!)
I started learning back in February 2022 when I was nearly 42, and successfully passed my skills test two days ago, 1st July 2024. My total hours before the tests (plural, I'll come to that shortly) was around 75 hours: 10 hours 40 solo and around 64 dual.
Learning to fly has always been a lifelong ambition. I had a trial lesson/ flight experience when I was 16 - a treat to myself from paper-round money - and since that point it is something I've always wanted to do. Until the last couple of years, I had not been in a position to take my dream any further. Then, for Christmas 2021, my fiancée (now wife) bought me a trial lesson. She very much comes from an aviation family. Her father has a PPL and met his partner/ my wife's mother as she was his flying instructor. My flying instructor through most of my PPL journey is my wife's cousin, and her uncle is HoT at the flying club and was also my skills test examiner... Got it? No, nor have I fully understood either!
When I first started, due to work commitments, instructor and aircraft availability, and the Great British weather, I was only having around one lesson per month. As you can imagine, progress was slow and, in hindsight, this should have been far more frequent (though I wouldn't have been able to control the weather). I also had four months away from learning from July 2022 when I got married, and a further couple of months off when my FI stepped down as an instructor.
For me, achieving a PPL has been a massive journey. I remember how daunted I was early on with the thought of nine exams ahead of me, as well as the practical elements of the FRTOL, QXC and skills test. It just felt it was a never-ending, and very expensive, journey. I think exams were even more daunting after passing my first exam, Air Law. It dawned on me I had to repeat the effort eight more times, potentially more if I failed any (fortunately, I didn't).
Along the way, I realise I was progressing a lot slower than perhaps some people you read about but, it's important to point out, that really doesn't matter!! My first solo wasn't until around 30 hours and I got a bit lost on my very first solo nav exercise! (Not so lost as to cause a problem, but I did get a gentle "turn 30 degrees to your left" over the radio!). Appreciate this doesn't paint a very good picture, but all this I learned from. Subsequent nav exercises I planned diligently, knew all ground features to look out for every few minutes, and knew how to use the kit in the aircraft properly!! (As well as having SkyDemon in my pocket in case of any real problems!)
All subsequent solo exercises went really well, including my QXC, and this helped provide the much-needed confidence that I could make a go of this.
However, there were times I thought “I can’t do this” and considered giving up. Circuit bashing was my nemesis and the reason it took me so long to go solo. There was inconsistency. I'd do six circuits, for example, and on every circuit/landing I'd make a different mistake. I can't even remember what now, but I remember very few circuits were perfect so definitely not solo material. It didn't help that there were sometimes a few weeks before I got to try again. Then, finally, on 27th June last year, I got things right consistently and out stepped the instructor and sent me off on my tod. That was the much-needed confidence boost and cemented my determination to continue.
Exams were the other cause for my dwindling enthusiasm, especially when preparing for the more difficult exams (meteorology for me. The feeling of elation (and increased lift on my shoulders) when I passed that last one was immense and well worth it.
In much the same style, my skills test (Sunday just gone) didn't go quite as well as it could have either! The first hour-and-a-half went really well. I was spot on with the nav and even my diversion was pretty accurate despite dropping my diversion ruler under the seat and having to improvise. Of all times to lose it, eh? General handling (stalls etc.) went OK-ish. I could have perhaps done better, but I was safe. However, it was the last 45 minutes of my test that got me. Where? Back in the circuits of course! My glide approach almost fell short and I tried to drag the aircraft in when I really should have performed a go-around and tried again. My powered landing had 10 degrees of flap, something I've never ever done (and will definitely not do again!), and my short-field landing fell the last 10 feet onto the runway causing a bit of a bump. A bit of an embarrassing end to the skills test. On the plus, my flapless approach was faultless!
Unsurprisingly, I received a 'partial pass', meaning all I would have to repeat to achieve a full pass is a few more circuits and repeat the landings after a 45-minute refresher with my FI. Wanting to get over the line, I went up the next day and passed! Mysteriously the centre line seemed to move for one or two of my landings, but apart from that they were pretty good.
If anyone's feeling they need a bit of encouragement after a bad lesson, or feeling like they're not sure if they should continue, my firm advice is stick with it. I did, and I got there in the end. Where I went wrong in my first skills test are areas I will remember for the rest of my flying career. In my opinion, that will make me a better pilot, right?
For me, however, the real learning begins now.
Rob P V2.0, UncleT, Miscellaneous and 7 others liked this
#2027057
Nice write up. Thank you.
It’s a good thing to reflect now on the ‘journey’, what went well, what not so well. This’ll help to give a few pointers so you can go on to hone your skills and spread your wings safely.
On the topic of hours taken to get it done, as you say, it really doesn’t matter. As long as you’re enjoying it and making progress, that’s all that counts. It’s pointless to compare learning to fly as a hobby with 18 year old students in the RAF. Anyway they get kicked out if they are a bit slow.
That last point I think is interesting. Teaching someone to fly who wants to spend their own money on it can a challenge - in the military the students are hand picked and weeded out by the selection process.
Also, I often found that someone who’d taken a bit of time and stuck with it ended up a better pilot and enjoyed their flying more than someone who found it all very easy.
Again, well done. And don’t forget there’s a huge variety of different types of flying you can do, different aircraft types to fly and additional skills to learn
T6Harvard liked this
By TopCat
#2027058
Firstly, very, very well done. :thumleft:
I'm sensing that actually you've understated the amount of pain along the way, so well done also on having the staying power to get to this point. I bet the family connection added a bit of pressure too.
Secondly, all of us here will understand that it can take a lot of determination and sometimes cussedness to press on through the disappointments and difficulties that can show up along the way to a PPL, and that having that says something important about a person.
Look forward to hearing more from you.
By johnm
#2027067
I started age 50 and I’m now well into my 70s Many of us will have memories triggered by your post I’m sure.
25 years on I hold an IR and have flown around much of Europe as well as in New Zealand and the USA.
As you rightly point out your journey and learning are now starting in earnest and we all wish you the best of trips :D :thumright:
By T6Harvard
#2027102
Well done all round!
Yep, it's tough at times but if it was easy every silly bug**r would do it :lol:
You are, of course, correct that the learning has only just begun. Every single flight from now on, and in fact every go/no go decision prior to a planned flight, is a lesson in itself. Never two the same, and that's the great thing about it, isn't it? Make sure you take time to simply revel in the priviledge :thumleft:
Speaking of hours.....
I took ages to get to solo. Probably a record number of hours.
A while after, having just started Nav, I had a little pity party, saying I was embarrassed about my high hours.
My Instructor looked me straight in the eye and said with the utmost sincerity, "But that doesn't matter, does it?".
He was correct, of course.
Flying is flying, whether solo, with an instructor, or doing a bit of the Skill Test again, it's still all an amazing experience to treasure.
Don't forget to post on the New Wings thread as PIC :mrgreen:
Nick liked this
#2027393
T6Harvard wrote:Well done all round!
Thank you!!
I remember the pity parties all-too well! I was like a moody child at times - "I'm no good" or "I give up"! So glad I didn't!
T6Harvard, WelshRichy liked this
By WelshRichy
#2027433
RichardTheGeek wrote:I remember the pity parties all-too well! I was like a moody child at times - "I'm no good" or "I give up"! So glad I didn't!
Oh I remember the pity parties all too well during my PPL, circuits were my nemesis as well. Just couldn't get them consistent.
Congratulations on passing your Skills Test, amazing feeling, isn't it? Enjoy your new found freedom. :D
My worst pity party was many years later, half way through my FI course, I had an awful flight sortie, wondered if I could ever do it. Was staying away from home so went out for dinner on my own, for the 15th night in the space of a month and oh did I mention it was my birthday? There was another birthday party in the corner and they had "friends". To cap it all off my car decided to have an engine warning light when I thought sod it lets go and get some make myself feel better chocolate. You really just couldn't make it up, but it is the honest truth. My wife just told me to go to bed and it'll be better in the morning!!! :lol:
And you know what? Yes, the next day was so much better and ended the third week on a very good note and I was fired up for the fourth week. :D
By Sir Morley Steven
#2029392
Well done on getting your PPL!
Some of my students, usually due to the intervention of life, have gaps and need to catch up. Initially they are frustrated due all the mistakes but we must all remember one thing. If you have the right mindset a mistake, properly corrected and briefed, is often a far more useful learning tool than getting it right.
Nick, T6Harvard, AndyR and 1 others liked this
