Lesson report from Saturday...
I got relatively lucky with the weather this weekend, having booked on Sat morning it was sunny and clear but with a decent wind (10-12 knots when we left, more like 15-20 at the end of the hour's lesson, about 40 degrees off the runway). Before we went out, I was given a couple of "solo student" indemnity forms to sign, which was suitably exciting / concerning, and a not so subtle hint that a first solo could be in the offing. However, when we actually went outside (walking past a pair of very shiny Extras and a Cirrus!) it was clear that the wind was picking up and a first solo would not be on the cards after all - so, plenty more crosswind circuit practice instead!
I definitely felt less rusty this time, thanks to the 20 minutes' flying from the previous weekend, and there were only two of us in the circuit (and no ATC) which also made the radio calls more relaxing. I actually got pretty much all of them right for a change! Because of the crosswind, I went for just 1 stage of flap for each of the landings, which resulted in me being a little fast and high on the first circuit although managed to sort it out quickly enough. The landing was OK although I think my instructor was helping out with a bit of extra rudder. Next time round was a bit better although I was again going about 10 knots too fast on base / final initially, having again forgotten how much less drag there is with just 10 degrees of flap. Because of the crosswind I was also overshooting the turn to final slightly, although again was pretty easy to sort out early on. Third time round I was encouraged to slow right down since there was someone backtracking on the runway, and I started to twig that I could use a fair bit less RPM while still maintaining plenty of airspeed and glide path.
A couple of circuits later we had someone joining the circuit just ahead of us on crosswind, which was a bit concerning having heard the "joining crosswind" call just as I was in a climbing turn to crosswind and couldn't see the other aeroplane! As we reached circuit height, they appeared closer in to the airfield just turning downwind, although reasonably close, and since they were in a (slightly faster) C172 there was plenty of separation by the time we turned final - they were already landing. Presumably they had already seen where we were when they joined, but it was the first time I had an aircraft appear "close by" on the radio which definitely prompted some hasty looking around!
In total we managed 9 landings in the hour, which on the whole went pretty well - one which felt like a really nice landing despite the gusts, one which could have done with being a little bit less "drifty" across the runway (more wing down needed) and you could feel the sideways load on the tyres when touching down, with the others feeling mostly OK despite varying crosswind gusts. Although I've just checked
https://www.flightradar24.com/data/airc ... b#2af27d94 and circuit 6 looks like a bit of a mess - not sure what happened there! (They all look a bit all over the place, actually, but I'm going to blame the crosswind again...). Main achievement: not forgetting carb heat at any point this time round!
When we had finished, my instructor mentioned that there was actually availability for the next couple of hours so did I want to do a first nav lesson?! Of course I did, but unfortunately I had already planned to go to a birthday party... never mind, I have the nav to look forward to for next time.
Finally, back in the clubhouse I bumped in to someone who has apparently been lurking on this forum and reading these posts! Even worse, they mentioned this fact in front of my instructor (who hopefully has far better things to do than read this forum
but if not, obviously they are the best instructor ever). So Mr Forum Lurker, if you're reading, great to meet you and sorry I forgot to ask your name at the time... no doubt there will be another opportunity in future!
