By PaulB
#1673496
Harry Brown wrote:The only way you can know CAP 413 is by reading it!
This is true, especially when it comes to the RT practical exam where you will be expected to use standard phraseology where it exists as HB states above.
If you don’t have CAP413 google it and download it - it has loads of examples.
#1673502
Harry Brown wrote:
There is no official “Deadside Descending” call in CAP 413
Cap 413 Chapter 4 Figure 2 (p98 in pdf) says "Report DEADSIDE DESCENDING".
as you say, read CAP 413.
And call signs should only be shortened when ATC say so. I have no idea where you got "STUDENT-CD" from - that is wrong.
Also, as this is the student forum, I suggest this isn't the place to debate the merits of the standard OHJ.
T67M, David Wood, Lockhaven and 1 others liked this
#1673657
RT CALLS
Thank you for your response. First of all you say you have no idea where I got “Student CD” from. As a PPL Examiner, FIC instructor and RT Examiner allow me to explain.
The use of the prefix “Student” is well documented in CAP 413, the UK AIP GEN 1.7 AMDT 12/2018 and both the Pooley & AFE Training Manuals. The Student prefix was introduced in the 80s and was originally based on the RAF prefix “TYRO”.
In relation to Student Flights CAP 413 (2.33) states:
Student flights 2.33
On initial contact, student pilots who are flying solo shall use the callsign prefix ‘STUDENT’. Once acknowledged, it will not normally be necessary for student pilots to use the prefix in subsequent transmissions until making initial contact with other ATSUs, unless they feel they are being instructed to do something with which they are unfamiliar.
Controllers will acknowledge the initial call, again using the prefix, and can be expected, in so far as is practicable, to make due allowance for the limited experience and ability of student pilots in determining the pace and complexity of instructions and/or information which are subsequently passed.
IT THEN GIVES SEVERAL EXAMPLES (I reproduce one)
Walden Tower , STUDENT G-ABCD, on the apron, request taxi for local VFR flight
2.35 Flight Instructors must brief students, specifically, on the use of this callsign prefix as part of their pre-solo briefing. The use of this callsign prefix is not intended to remove the additional requirement for flight instructors to notify ATSUs separately of ‘first solo’ flights where this is normal practice.
So now you know where I got STUDENT G- ABCD from (hopefully) Ensure you understand the legal definition of MUST too because you should have been taught this during your training unless you were pre TYRO!.
When, after ATC has first of all abbreviated the full callsign, you may in turn abbreviate your full callsign, as you correctly pointed out and you can be sure that I know that because I've been teaching it for the last 40 years!
My point was, which I think you missed, is when you abbreviate it, it shouldn't be abbreviated to STUDENT G-CD, it abbreviates to STUDENT - CD. CALLSIGNS for AIRCRAFT 2.26 table 10 shows why. See the SPEEDBIRD example and this should explain.
#1673666
Secondly you mention the MERITS of the Standard Overhead Join. You do not think it should be discussed in the STUDENT forum, I disagree, although I am not actually discussing it's merits, I think its a lovely join that always reminds me of 50s Tiger Moth flying! But times change and so does ATZ traffic, there are things flying around ATZs now that frighten me even when they are in the hangar and the increase in helicopter training has been dramatic. So being one of those types of instructor who genuinely trys to understand and promote duty of care I am trying to get STUDENTS to think along the lines that,
many airfields do not have standard overhead joins anymore.
For instance at one airfield if you descend to 1000 ft on the dead side you may well hit a glider coming the other way or at another you may just clear a helicopter by 250 feet coming the other way. I say clear but if your 125 feet low and he is 125 feet high the only thing that is going to be clear is the collision!
This the Join for Booker, hardly standard is it
Joining aircraft are to position to overfly the runway in use at 1200 ft QFE on the runway QDM. When overhead the midpoint of the runway turn left or right (depending on the circuit direction) to level at circuit height 1000 ft QFE on the crosswind leg prior to turning downwind
As I said there is no official “Deadside Descending” call in CAP 413, the text (which forms the rules, not the diagrams) does not contain such a call, the text I reproduced in my initial post, which you should be familiar with, is in chronological joining order lifted straight out of CAP 413. You point out there is a very dated diagram that CAA have been using for years saying:
“When runway and circuit direction are ascertained begin letting down on the dead side. If required, report DEAD SIDE DESCENDING” You forgot to mention “IF REQUIRED”!
If you look at the current much more up to date SKYWAY CODE, Aerodrome Operations Page 100, you will see that no such call is mentioned in the joining diagram (note the straight line descent pattern which is also at odds with the one mentioned above in CAP 413)
In addition, nowhere in The Skyway Code will you see the phrase STANDARD OVERHEAD JOIN, in fact when mentioning joining it cautions:
“You must check the local procedures for the aerodrome you are using”
If you also look in the AFE training manual, you will not find STANDARD OVERHEAD JOIN in the index but you will find Overhead Join.
If you also look at the CAA Safety Sense Leaflet 6E AERODROME SENSE you will also see that the O/H Join diagram does not show a call for descending deadside. In fact the ridiculous dated diagram does not even show any need for an overhead call at all, only a Joining Call! Notice they say the diagram is taken from CAP 413 (so why doesnt it show a deadside descending call, the present CAP 413 diagram does) Also notice in the text it says the Standard Overhead Join is called the Overhead Join! The link to the Overhead Joining Poster is broken too! However when you do find the poster it says its a STANDARD OVERHEAD JOIN and guess what no deadside descending call is shown at all! However when that same diagram appears in THE SKYWAY CODE its called the OVERHEAD JOIN and again no deadside descending call!j
It's also worth looking at The Gloucester VFR Guide as they are reputedly the busiest GA airfield in tbe country, not a shining example of CAP 413 Phraselogy but useful to consider because they may ask you to report in two other positions after the overhead! Descending or Crosswind!
Confused? Think how students, whom you don't want to know any of this, feel.
The above actually highlights yet another reason of why UK GA training can be very non standard!
#1673694
Yes - of course I know about the student prefix to a callsign.
But ATC never asked me to continue to use "student" after initial call. Student GABCD has always been shortened to G-CD. I have continuted to use it in an non-atc field which was busy to warn others.
If the pilot reported as "Fastjet Speedbird GABCD" then it would still be abbreviated to Speedbird CD, as Fastjet is another allowed prefix.
Another prefix can be "Mayday". You don't change from G-ABCD, to your initial abbreviation (by ATC) of G-CD to Mayday-CD.
The only example of a prefix being used as the call sign, rather than just as a prefix, is when it is used as a type ("helicopter CD").
CAP 413 clearly describes the places to report for a standard overhead join, in a mirror diagram and wording to how it describes where to report in a normal circuit. Do you also say that it doesn't officially say where to report in a normal circuit?
The "as required" is because ATC may tell you where to report. If you aren't at an ATC field and are performing a standard overhead join, you need to report deadside descending.
The standard OHJ poster that is commonly used doesn't include any reporting points. Skyway Code is too big to open on my phone.
You have to follow local patterns of course. Near me, Standard OHJ is fine at pretty much every landing place. Many places elsewhere have noise abatement circuits. You need to learn, as a student, what the standard is, then to adapt that to the place where you are flying. You teach / learn thr standard, then expand that to the specifics of where you are landing.
#1673703
riverrock wrote:Yes - of course I know about the student prefix to a callsign.
But you dont! ATC will never ask you to continue to use the student prefix. Its at the prerogative of the student whether he/she wants to use the prefix after the initial call, it clearly says that in CAP 413.
By T67M
#1673708
I'm with @riverrock - ATC will always respond to a student's initial call with either "Student G-ABCD" or "Student G-CD". The student may then continue with "Student G-CD" or simply with "G-CD". No-one should ever use "Student-CD".
#1673720
riverrock wrote:.
With respect can I say as someone who regularly used the Speedbird prefix your talking complete nonsense where an earth did you get that from?
A pilot wouldnt use 'FASTJET SPEEDBIRD' anyway because they are two different prefixes, one is airforce and one is civil!
Apart from that, thats nothing to do with what you originally posted you said you had never heard of Student-CD, well Student CD is tbe correct abbreviation of STUDENT GABCD. In tbe same way as if you are KNOWALL GABCD tbe abbreviated version is KNOWALL-CD
You dont abbreviate a MAYDAY call because the ATSU dealing with a Mayday call will never abbreviate it, at least they are not supposed too, They always use your full callsign when replying so you should use your full callsign in your reply but thats got nothing to do with the above.
GOLF is a nationality prefix
STUDENT is a prefix
SPEEDBIRD is a prefix
FASTJET is a prefix
you only need one prefix in front of an abbreviated two letter callsign.
By PaulB
#1673728
Harry Brown wrote:GOLF is a nationality prefix
STUDENT is a prefix
FASTJET is a prefix
Not according to CAP413.....
It says this about the student prefix which might be classed as a special prefix as opposed to the "normal ones in the pic above.
prefix ‘STUDENT’.1 Once acknowledged, it will not normally be necessary
This is a student forum and as such should be a learning environment. It's not a wi11y waving competition.
Lockhaven, Flintstone, AlanC liked this
#1673729
T67M wrote:I'm with @riverrock - ATC will always respond to a student's initial call with either "Student G-ABCD" or "Student G-CD". The student may then continue with "Student G-CD" or simply with "G-CD". No-one should ever use "Student-CD".
What an ATSU (not ATC which doesnt include FISOs) chooses to say doesnt mean its correct CAP413 terminology or procedure
Table 10 in CAP 413 shows
Speedbird GBGDC is abbreviated to Speedbird DC
Using your logic the abbreviation would be SPEEDBIRD G-DC , it isn't!
#1673733
STUDENT is a prefix
FASTJET is a prefix
You must have a diferent version of CAP413 then because even the table, which I quoted and youve inserted shows clearly they are prefixes!
By PaulB
#1673736
Harry Brown wrote:You must have a diferent version of CAP413 then because even the table, which I quoted and youve inserted shows clearly they are prefixes!
This is the one I used....
https://publicapps.caa.co.uk/modalappli ... il&id=6973
Maybe there are 2 versions on the CAA website or perhaps the doc contradicts itself in different sections.
#1673738
Harry Brown wrote:
riverrock wrote:.
@Harry Brown
British Airways, maybe I know you, but better still I think I may have even flown with you, everything is becoming clearer day by day :wink:
#1673744
[quote="
This is a student forum and as such should be a learning environment. It's not a wi11y waving competition.[/quote]
Its those sort of crass comments that preclude learning, if you cant be a professional at least try and act like one.
To make it simple
If you started an airline called 'Student Air' and your callsign was "Student" and your aircraft was GABCD, using tbe CAP413 Spedbird example I gave you what would your abbreviated callsign be for STUDENT G-ABCD?
Ive nothing more to add to this discussion. Lochavaon, ive blocked you so I cant see any of your posts-and Golf Hotel!
