Fri Sep 01, 2017 10:35 am
#1556290
Had an interesting moment on a recent flight with a new instructor. I'm about 30 hours in of which 8 has been solo, have done a few solo navs and a solo land away, all without too much drama.
In prep for QXC I wanted to fly one of the legs that I'd not seen yet, so booked in a flight with a club instructor who I'd not shared a cockpit with yet(usual inst. was away).
Anyway, idea was to land at first airfield then overfly the second on a QXC route. The full stop airfield has a hard runway, with 3 shorter grass strips to the SE. We were asked by the AFIS to use one of the grass runways, which the instructor queried, AFIS responds due to considerable crosswind on the hard. Runway then confirmed back to AFIS, check of aerodrome plate then perform overhead join. Overhead I note the runways and the active, then see an aircraft taxiing towards active runway, and a tractor mowing the grass area to the south of the runway in use. Turn onto what i think is final, instructor points out I'm aiming for the wrong runway (20 degrees off). Which I am. I'm far enough out here, no other circuit traffic, swing the nose round, get visual with active runway - on the centerline - see the numbers. All ok. Instructor repeats that I'm heading for the wrong runway, and asks me to change direction. I look up, check the number, flick to the compass, and they confirm the active. Check the plate, runway confirmed as correct. The aircraft that was taxiing has called holding at a point to the left of the runway threshold. Double check the numbers on the runway again. They match.
65kn, three stages of flap -300 feet. Instructor demands that I change change direction and land on the numbers over to the left (looking at the map later the numbers are for a runway that's almost 90degrees to the active). This would take me directly over the holding aircraft at low level and into an area where I have positively confirmed a tractor is operating (I still have visual with it), not to mention there's no confirmation a runway exists there. So i challenge the instructor to read the numbers on the runway ahead and confirm they match the runway in use. A slight pause, then confirmation that the runway is correct. 30 seconds later I perform a reasonably smooth landing. Instructor apologises, I apologise for lining up on the wrong runway in the first place. Rest of the flight goes to plan.
In retrospect, it was a tricky situation - from an evidence perspective, shortly after the initial correction I could see with 100% clarity that the runway numbers matched those in use. The suggested runway number couldn't be easily read (as they were at 90deg to our viewpoint). A look at the plate supported the visual situation, and the position of the aircraft holding (and it's holding point) supported the assessment ( although i do realise this aspect could be easily misrepresented from the air).
From the instructor's standpoint, they had already had to correct me and might therefore assume that my judgment is impaired.
This was the first time I'd experienced something of this nature in the cockpit, and I'm sure whilst there's differences in opinion, I don't think that landing was the right course of action, regardless of any evidence. I could have handed over control to the instructor and said "fine, you land where you like, your aircraft" but is that responsible if I have visual proof someone is about to land somewhere potentially dangerous that could put us both in danger?
I suspect the answer is "s**t happens, people make mistakes, call go around and clear it up at 1000 feet, not 200!" but would appreciate some guidance from those of greater experience.
