AV8 Inspector co2 gadget…
PostPosted:Fri Jan 21, 2022 1:06 pm
by Fellsteruk
Hey,
Anyone else ordered or using one, I’ve been after a portable/digital co detector for a while and with the 20% off I thought why not…
Them paper disc things seem useless
I’m always convinced I’m being slowly killed when cruising and not helped when I get tickle in my through or nose so this will if nothing else prove I’m right or give me piece of mind
Re: AV8 Inspector co2 gadget…
PostPosted:Fri Jan 21, 2022 1:48 pm
by EdH
I tested both units for the February 2022 issue of FLYER. Great piece of kit, and infinitely better than the plastic discs!
https://issuu.com/flyerdigital/docs/fly ... ry_2022/60
PostPosted:Fri Jan 21, 2022 2:26 pm
by Fellsteruk
I should have read that before I picked which one to buy… o well I’m sure I’ll be happy with the cheaper of the two models.
PostPosted:Fri Jan 21, 2022 3:33 pm
by riverrock
Alternatively, for£20....
https://www.amazon.co.uk/Fireangel-CO-9 ... B00441S9GS will last for 7 years, doesn't need calibrated (they recommend you test it yourself using an incence stick yearly), and has delayed alarms (so less false alarms) based on the level detected. We attached it to the aircraft with some velcro. Depending on which vents, stage of flight I'm in and cabin heat, I get between 27ppm and 0 (less than 10ppm). The display shows buildup over time.
The alarm will sound:
• Between 60 and 90 minutes when exposed to a minimum of 50ppm of CO.
• Between 10 and 40 minutes when exposed to a minimum of 100ppm of CO.
• Within 3 minutes when exposed to a minimum of 300ppm of CO.
PostPosted:Fri Jan 21, 2022 3:47 pm
by Fellsteruk
I did look at them but I rent and already have to carry a packed bag so constantly trying to keep things small and I had visions of being woke up it going off because something was pressing against the massive test button
EDIT:
Just read the article, good review
@EdH given the flying I do I’m not worried I didn’t go for pro model, it’s also good to know it may work for longer than 2 years and I didn’t know you can get a new sensor for $69 so that’s good.
You never know, maybe the CAA will do a rebate on these devices after the trial if they prove useful but I don’t see how they couldn’t as by the time you think you may have high co2 exposure it’s likely too late and in all reality you won’t notice and you’ll be unconscious.
PostPosted:Fri Jan 21, 2022 7:08 pm
by Rob L
To some of the above posters: It's CO (carbon
monoxide) which is the larger threat to pilots in their aircraft and their homes too, not co2 (which doesn't exist...CO
2 exists; that's carbon
dioxide
])which is also unhealthy but largely unlikely to affect pilots.
As is Cobalt (Co) of course: it'll turn your teeth blue as you chew it.
PostPosted:Fri Jan 21, 2022 8:45 pm
by Fellsteruk
Good point not sure why I put co2 in title dingbat mistake I can hear my a-level chem teacher disappointment.
PostPosted:Fri Jan 21, 2022 9:18 pm
by Nick
I use a forensics CO detector. On two occasions I have warmed my aeroplane up with the door open in very still and hot temperatures. It has recorded 9ppm but then cleared to zero once the door is closed and I have taxied away. I find this very reassuring that it works. I was unable to sense any exhaust fumes at all.
Available from LAS at Oakhampton.
Hope that helps.
Nick
edited spelling
PostPosted:Fri Jan 21, 2022 9:59 pm
by Miscellaneous
@Nick are you sure it's not just an ornament?
PostPosted:Sat Jan 22, 2022 8:31 am
by Nick
