#1850171
I believe Sky Echo will only work from its internal battery, and will not work whilst the battery is charging. Plugged into the USB port in the plane for example?
I believe it's designed this way for a reason, does anyone here know the reason?
Thanks
By Dave W
#1850216
I've just tried it, and SE2 still apparently transmits on ADS-B whilst charging (the green ADS-B LED cycles as expected).
There's nothing in the manual I can see that suggests it doesn't.
#1850257
Hellsfish wrote:I believe Sky Echo will only work from its internal battery, and will not work whilst the battery is charging. Plugged into the USB port in the plane for example?
Thanks
From the subject line I though you were going to tell us! :D
