By foxmoth
#1838967
The time on our Dynon is about 30 mins out, someone in the group had deselected the GPS and time was then well out so thought that was the problem but now have re set it and clock is still not right, any suggestions?
By Trent772
#1838980
There are plenty of links if you do a quick search. Seems to be resettable in the sub menus of set up, but I don't know which device you have.
By foxmoth
#1838989
Dynon skyview, not sure which one without going to the field, fairly early one. Had a look in the setup and instructions but can’t find anything there also tried a search and again not coming up with anything
#1839055
On our MGL this is a sign of a failing internal battery
By Trent772
#1839087
That was also mentioned in quick search.
Dynon back up needs normal line voltage to recharge, won't charge on a battery float charger. If it hasn't flown for a while, once it has been airborne for a couple of hours, reset it again and do the battery capacity test on the back up.
By foxmoth
#1839102
Thanks for the suggestions. Flown relatively frequently - a couple of us are instructors so able to fly for currency even in lockdown, and did a battery test not long ago so don’t think it is that,.
