Sat Apr 03, 2021 1:09 pm
#1837726
Flew cherokee 180 this morning.--had report from another member ref brakes--checked out as engineer works from short strip--I usually pop it over to him for odd problems--while you wait service.
The right brake is not working.--so when you brake pulls to left.
The left brake is ok.
Happened a few weeks ago--engineer bled right brake--initially ok.
Using handbrake veers to left -as expected---countered by pushing right rudder.
Based on field with ginormous runway so long enough for it to run out of steam.
Any thoughts other than air on one side -but apparently not on other.
Brake shoes replaced at same time..
Will see engineer next week but any thoughts from members experience of similar?
