By Fellsteruk
#1820554
Been looking at Zulu3’s and noticed they have an app Flight link which records your RT and allows playback in flight.
Anyone used it, is it any good.
#1820555
For Zulu 3, Tango, Sierra, PFX, and Zulu.2
By skydriller
#1820564
Ive used it and it works as advertised. Good quality recordings.
You need to make sure the dip switches are set up correctly.
Bluetooth for calls/music also good. The reason I chose the Zulu 3 though was due to the fact that Lightspeed will send you a different headset cushion, which is great for those with a smaller headsize - like my GF/partner.
By Fellsteruk
#1820593
I was set on a20 to upgrade from my passive DCs but the Zulu3 seem to do everything the a20 does for less and actually like it’s construction, seems more durable than a20 however I’d be treating either like a baby
As a glasses wearer I think the bigger/more padding on the Zulu will make for a better seal around the old egg head.
