Sat Dec 26, 2020 12:03 am
#1816480
I also have the Fireangel 9D and just re-insert the two pronged key after flight that has to be removed to activate the detector.
smokescreen wrote:I also have the Fireangel 9D and just re-insert the two pronged key after flight that has to be removed to activate the detector.
rdfb wrote:smokescreen wrote:I also have the Fireangel 9D and just re-insert the two pronged key after flight that has to be removed to activate the detector.
I had been doing that, but one time whatever is inside the holes the key connected to broke loose and rattled around inside. So I got it replaced and then stopped doing that.
I also don't think it'd be practical to insert during flight.
35ppm
The maximum allowable concentration for continuous exposure for healthy adults in any 8 hour period, as recommended by the Occupational Safety and Health Administration (OSHA)
200ppm
Slight headache, fatigue, dizziness, nausea after 2 - 3 hours
400ppm
Frontal headaches within 1 - 2 hours, life threatening after 3 hours
800ppm
Dizziness, nausea and convulsions within 45 minutes
Unconsciousness within 2 hours
Death within 2 - 3 hours
GrahamB wrote:200ppm
400ppm
rdfb wrote:GrahamB wrote:200ppm
400ppm
Just be careful. "Slight headache, fatigue, dizziness" sounds like a half hour diversion to a suitable aerodrome might be appropriate, but the description says nothing about what your ability to control and land an aircraft is going to be like after that half hour diversion. With the accompanying hypoxia, my understanding is that you are likely to misjudge your own ability at the time, too.
rdfb wrote:
I made a 3D printed mount for this particular device if anyone wants one.
Mine is just on Velcro currently - a bit wobbly. Could you post a pic of your mount for it please?
If it looks appropriate my grandson could probably do me one if you will share the file.
I'd be happy to print one and drop it in the post the next time I have my printer out.
