Wed Oct 03, 2018 2:49 pm
#1641965
On every start bar the last two, the oil pressure indication has steadily reduced as the oil temperature indication increased.
On the last couple, there's been a little fluctuation towards the end of the process, and on the last flight the oil temperature indicated significantly higher than normal around 10 min.
The aircraft has an oil cooler bypass fitted.
My guess is it's the bypass valve - any other ideas?
ISO 3103 compliant
