Sun Jul 30, 2017 12:18 pm
#1549820
So......
My next technical query i'd appreciate feedback on is...
When an aeroplane suffers a heavy landing to the extent an undercarriage leg ends up a few degrees from being parallel with its other leg, would you expect the forces that caused the bend to be confined to the u/c or, to have spread into other areas of the airframe, causing potential similar but unseen damage.
This really is an open question - and i apologise for that - obviously there are lots of factors at play but....
where the port u/c and tailwheel both needed repair, my cautious non-engineering background would lean towards stripping the fuselage fabric (although it shows no creasing, damage) and measuring/checking the metal tubing for other hidden gremlins...
...or did the u/c leg do its job by bending so damage was local..shot peening further disclosing the extent of the 'injury' and therefore i'm being over cautious.
as ever, feedback from you is most appreciated.
tty
tty
