It depends. The main thing is that the antennas have a good view of the sky.
The PilotAware transmits once every 1.8 seconds or so, so you might hear a click at that time if it's too near to something else.
I put mine on top of the dashboard.
flybymike wrote:How do you secure it?
flybymike wrote:And does it not interfere with the view out of the window, thus negating at least some of its benefits?
GrahamB wrote:I may cut the Mode S antenna down to half length, so I can slide it further forward on the coaming, but it doesn't really need it.
ChrisRowland wrote:GrahamB wrote:I may cut the Mode S antenna down to half length, so I can slide it further forward on the coaming, but it doesn't really need it.
Reducing the length of an antenna is a bad idea because the length defines the wavelength that the antenna is sensitive to.
