Rob P wrote:B*gg*r me. I managed to plug-in the odds and ends, configure it and get it working unassisted.
And I am the ultimate numpty.
Excellent.
Does that mean the RV6 is back from the radio doctor ?
Ours is currently in the operating theatre having new Trig boxes fitted and I am looking at options on what best to use as an unobtrusive gps unit that can sit behind the RV7 panel to drive the ADS-B bit on the Trig TT21.
As a fellow numpty, I have a couple of questions that you might be able to help with:
Firstly, Does your PAW unit have facilty to hardwire the GPS output to the txpdr that I would need.? If so, it would make lots of sense to use PAW box for this and gain benfit of another level of electronic conspicuity to add alongside the Powerflarm we already have fitted.
(edit- I realise that I could use the PowerFlarm for GPS source but it sits atop the coaming and I am looking to keep visible cabling to a minimum - so I am considering using a PAW unit hidden behind the panel (next to txpdr box) that will switch on with avionics master to provide gps info to txpdr)Secondly, where have you found best to place the PAW antennae in the RV to give goood forward/ lateral visibility?
