Mags are hardly rocket-science , having superseded Hot-Tube or Trembler- coil , around a hundred years ago..
So, let's look at the maintenance- issues.
bearings-ball-races will usually do several thousand hours, as can be testified by the millions of cars and other machinery that's scrapped with ,for example, factory-fitted wheel-bearings.
500 hours/5 years between regreasing would be reasonable.
Slip-rings/brushes. Unlike a Commutator, no segment-edges, so akin to an Alternator, which commonly will do 150K miles (say 3,000 hours @ average 50mph.)
basically, a "life" item.
Points/ condenser ....even in the days of inferior fibre "heels" on the moving points, coupled with unsophisticated cam-profiles and poor lubricants, 250 hours intervals between clean and reset.
modern materials and design could probably double that.
Insulation breakdown.... A real problem with old, organic lacquers...should be a thing of the past, with modern resins- just look at the armature of any small, modern electric motor,in even the cheapest tool/appliance.
Permanent Magnet....As with lacquer, stupendous advances in flux-density and power in a smaller, lighter format,with modern ceramic magnets, means weak fields are history.
The critical issue is setting the points to the magnetic "break".... OK, that's 10 minutes of skilled, practised work.
To strip clean, re-lube and reassemble a mag with an impulse-starter (a very basic, primitive device of springs and centrifugal weights) should be less than 6 hours of semi-skilled labour.
Where those barmy prices come from,defeats me. monopoly abuse?
A brand- new one should be about £50, ex- factory.....add -on margins.....£100 now add all the paperwork, liability- insurance, inspections, certification (and the profit -margins on all that!) We're at £500-£800 now Oh, and don't forget the £100- £200 VAT !
More wear, tear and damage is being done by constant stripping/"overhauling" and rebuilding, than actual usage wear and tear.
bet there are many stationary-engines, boats, tractors and motor- vehicles with Mags that reliably do 30 or more years between any sort of work other than points-set /replacement.
just another Aviation stitch-up.
The fact that Permit and SSDR machines are not raining-down on us, would suggest the Certification regime adds nothing to GA safety and is certainly not cost-effective.
Awaiting flames, Nomex suit donned!
