Fuel duty drawback - online form link
PostPosted:Thu Oct 08, 2015 10:29 am
by TheKentishFledgling
As requested, a stuck thread with a link to the "new" drawback form:
https://public-online.hmrc.gov.uk/lc/co ... e=HO60.xdp
Re: Fuel duty drawback - online form link
PostPosted:Tue Oct 27, 2015 10:41 pm
by mixsfour
Thanks, this is very useful. How about changing the title to something like "Everything you wanted to know about flying abroad but were afraid to ask" and adding some more links - there's some great contributions around the forum and it would be good to have links all in one place.
PostPosted:Mon Nov 02, 2015 7:08 pm
by Clive
PostPosted:Sun Aug 07, 2016 5:07 pm
by Stu B
I have never had any problems getting my refund despite having a (UK-based) German registered aircraft - but does anyone know if continental pilots visiting the UK can also make a claim? I'm organising a fly-in shortly and some of the visitors will be from across the Channel and might well be interested if they can!
PS - as regards Mixfours's request above for other cross-channel info, Dave White's excellent documents "Want going Foreign Info? (
https://dl.dropboxusercontent.com/u/66162937/Posted_Files/Why_Not_Fly_to_France_2016-v4.4.pdf )and French RT Kneeboard (
https://dl.dropboxusercontent.com/u/66162937/Posted_Files/Why_Not_Fly_to_France_2016-v4.4.pdf) should be just what you are after!
PostPosted:Wed Sep 07, 2016 3:48 pm
by map5623
The only issue with this 'online' form is that it has to be printed, signed and sent in the post, 7 pages 4 if you can print 2 sides.
Hardly online by today's standards, bearing in mind that many people completed tax returns, vat etc online.
Re: Fuel duty drawback - downloaded the online form
PostPosted:Wed Sep 07, 2016 4:03 pm
by Flying_john
I downloaded it once and stored it on my PC and just fill in the bits that change each time.
Just change the dates and amounts of fuel loaded print and sign, job done.
PostPosted:Thu Sep 08, 2016 7:52 am
by Stu B
I *thought* I had tried to do that and had been unable to - I must try again, it would certainly save much of the faff!
PostPosted:Thu Sep 08, 2016 9:19 pm
by Flying_john
Its a bit of a faff the first time round as you need to save the PDF and then use a PDF editor (I used an on-line one) then save the result and use the edit and sign option in Adobe to alter it each time you need to make a claim.
PostPosted:Fri Sep 09, 2016 7:45 pm
by Stu B
Ah, thanks, I thought you meant there was a "direct" way to save a version that coudl be updated for each future trip, but the method you suggest still sounds worth doing.
PostPosted:Sun Mar 05, 2017 11:17 am
by NigelC
Have been trying to fill in this form all morning and the website keeps crashing before you can print the form. I then notice this is a BETA version.
You have to retype the address of suppliers even if it is the same one, you cant save details which are the same each time.
Typical Government IT rubbish designed to frustrate people into not claiming.
PostPosted:Sun Mar 05, 2017 11:23 am
by Nick
Yes. I came to the same conclusions last year and gave up. I decided it wasn't worth the effort.
Nick.
PostPosted:Sun Mar 05, 2017 12:23 pm
by skydriller
If it has to be printed out and signed and sent by post, what was wrong with the old one which I have lurking on my hard drive? And can you still use it?
Tech is supposed to make your life easier, not harder and complicate things...
Regards. SD..
PostPosted:Thu May 04, 2017 9:37 pm
by Lefty
There is a lot of anecdotal evidence that this is part of a campaign to make more difficult for pilots to claim drawback.
PostPosted:Sat Jul 09, 2022 1:52 pm
by ROG
Put---- HO60 drawback---on google---fill in form--print off 2 copies---keep one.
send to address on form--cash received 42 days later---no problems.
