Texel (EHTX)
PostPosted:Sat Jul 02, 2011 10:19 am
Texel airfield is located on the most southerly of the chain of Frisian islands that run parallel to the Dutch coast and extend along the north German coast.
This is a grass airfield with two runways, the main runway is 1115m aligned 04/22 and the shorter runway is 630m aligned 13/31. They are both clearly marked by large bollards and there is room to taxi to the end of every runway in a cut grass area to the side of each runway set of markers.
Texel Airfield
The runways seemed pretty smooth and well kept to me, I used both 22 and 31 in the course of my one week trip.
Getting to Texel itself from the North Sea may seem liken a challenge due to the military areas, but in practice it was not problem. You can squeeze between areas R8 and D41. If approaching along the chain of islands from the east, we were immediately granted transit of R4 / R4A (and it was a normal weekday).
Texel is only a radio service, so they don’t say much.
Being a grass airfield, I did find it not easy to spot immediately. They do NOT like you overflying the airfield as there is also frequent parachute dropping.
Report to the tower building and up the stairs into the tower itself. There they have an internet PC free for use and free WiFi (ask them for the password).
The fuel pumps are in front of the tower by the windsock. Fuel pump is self-operated, just ask for fuel on landing and they will ‘turn it on’ remotely from the tower, so all you have to do is pick it up and pump. Being the Netherlands, the fuel is expensive (EUR2.78 a litre as at June 2011).
Texel Tower from the pumps
The airfield has an excellent website and a webcam that you can click on links to get different views of the airfield.
http://www.texelairport.nl/
They say 12 hours prior notice for customs, but are also happy just to take your details when you land.
Landing fees for sub-1500kg aircraft are EUR14.00 on weekdays and EUR17.50 at weekends.
They are very friendly and helpful in the tower and generally around the airfield.
They did say just ask them in the tower if you want accommodation and they can fix you up with something to suit. There is a hotel literally in the airport building, but this is said to be a ‘suite hotel’ and so expensive, even with a discount for pilots.
They were also very happy to lend you bicycles for trundling around the island. It looks like a really nice island and probably warrants a couple of days stay and cycling.
There is an excellent café on the airfield, much used by the locals (always a good sign). There is also a small flying museum, admission EUR4.
Texel Airfield
