Mon Jun 22, 2009 3:44 pm
#762464
Go for a walk along the sea front with an ice cream!!
CPL, IMC, FI(A)... And a beige devil.
Moderators: deltacharlie, GlosOps
nadders wrote:1.File flight plan with Doncaster and get it activated once airborne.
Depart, asking Le Touquet ATC to activate flight plan.
Have I missed anything out??
spacon wrote:I was under the impression the AFPEx is a world-wide thing, maybe i am wrong.
jollyrog wrote:Consider landing at Lydd on the way out. If you fill up there, you'll have a full tank for drawback purposes, which is about £63 on a PA28. Best value obtained if the last leg of your journey starts on a full tank.
1) If you fill up at Lydd when you don't need to, you end up getting re-fuelled duty free, and are therefore unable to claim for the rest of the fuel in the tank. You lose out.
The drawback rule is for exported fuel so theoretically you can claim duty back on every drop you export irrespective of where you bought it.
In practice most pilots simply submit their last invoice and hope its for a lot. I am not sure how you can claim for a full tank. Maybe submit the last two invoices together with the relevant bit of the POH showing tank capacity with a supplementary affidavit from the ground crew saying it was sloshing out the top of the tanks?
Chilli Monster wrote:1) If you fill up at Lydd when you don't need to, you end up getting re-fuelled duty free, and are therefore unable to claim for the rest of the fuel in the tank.
Morley wrote:The drawback rule is for exported fuel so theoretically you can claim duty back on every drop you export irrespective of where you bought it.
Morley wrote:In practice most pilots simply submit their last invoice and hope its for a lot. I am not sure how you can claim for a full tank. Maybe submit the last two invoices together with the relevant bit of the POH showing tank capacity with a supplementary affidavit from the ground crew saying it was sloshing out the top of the tanks?
Morley wrote:My point was how do they know the capacity of the tanks? What if I have long range ones? Do they check?
