Group flying opportunities & questions
#2025665
I am selling shares in a superb 1979 Reims Cessna F182Q, with rare BRS Chute. Possibly one of the best you will find in the UK. She is not being flown enough and is ideal for someone looking for a serious touring aircraft that you can also take into small grass strips! I am looking for either a 50/50 partner, or would also consider selling 2 shares to create a 3 person group.
She is a brilliant all round aircraft that had a major refurbishment done by Multiflight in 2019 with new modern glass avionics, new interior with cross-stitch leather, addition of a BRS chute (same as Cirrus and great for added safety when flying at night), recent prop overhaul, and many other updates.
Fully IFR with glass and 3 axis Garmin 507 AP.
Compliant with all Cessna SID inspections and CPCP corrosion prevention and control programme. Maintained under full CAMO by the excellent Multiflight since purchased in 2019.
Hangared at Cardiff (EGFF) which is open 24/7 most days making returning at night possible most times. One of the best 182s you will see or fly. No expense spared.
Serial - 0126
Total Airframe Hours : 6250 Flight Hours (increasing as in use)
Annual due - Dec 2024
ENGINE
Continental O-470-U - approx 831 hours since overhauled 29-July-2008 (increasing as in use)
INTERIOR CONDITION
Almost as new: Interior completely and professionally refurbished in 2019 by Aircraft Interior Refurbishment, including fully re-upholstered leather (diagonally stitched pattern) seats, head rests added, side panels skirts, and carpet replaced, all interior plastics repaired / repainted, and new instrument panel. 10/10
EXTERNAL CONDITION
Repainted approx 2005. All fairings replaced with new in 2020. New front nose spat 2021. Very good 9/10 with a few chips. New LED lights and LED tail beacon added in 2021.
PROP
Prop - Mccauley 2 blade
Prop governor overhaul 2019 (new one being installed in July)
Prop hub replaced 2019
Total Prop Hours : 130 since overhaul 15-Dec-2021 (increasing as in use)
PANEL
Garmin GMA 350c - Audio Panel
Garmin GTN 650 - Nav / Com / GPS
Garmin G5 x 2 - PFD/MFD
Garmin GMC 507 - Autopilot (3 servo), with level button. Servos all replaced in Dec 2023. PBN approaches etc
Garmin SL 30 - Nav / Com
Bendix/King KN64 - DME
King KR87TSO - ADF (currently O/S)
TRIG TT31 - Mode S Transponder /ADS-B capable
MISC
Rosen Deluxe Visor Kit 2019
New Olio Assembly 2019
Lord Shimmy Damper fitted 2022
New Starter motor fitted 2020
AeroLED LED Landing and Taxi lights fitted (with pulse) 2021
Electric Pitch Trim Motor
LH & RH Magnetos replaced in 2020
2 Concorde RG24-11M batteries (1 spare for cap check cover) -2020/2021
Interior lights rewired (including panel) 2021
Long range tanks
BRS Parachute System 2019 (line cutters to be replaced July)
4 Person Liferaft
All Cessna SIDS and CPCP inspections
Always hangared since purchase
Serious enquiries only please message me or email at cgriffiths (at) opengenius.com
EDIT: Images can be found on Afors....
https://www.afors.com/aircraftView/6188 ... el-Cardiff
Last edited by WalesFlyer50 on Thu Jun 20, 2024 10:28 am, edited 2 times in total.
MikeB liked this
