Mon Oct 09, 2017 9:57 pm
#1564346
1/3 temporary share in a ROKO NG4 (Bristell NG4 2 seater) G-CGMV based at Charlton Park )(Private Strip with long good quality runways)(Near Kemble). Share cost £3000 (Guaranteed buy back). The monthly payment is £150 PCM and the hourly rate is £100 per hour wet. The aircraft is rarely flown and has been well maintained since built in 2010. The aircraft cruises at 110 Knots and has a very good load capability especially when compared to a Sportcruiser.
Dynon Autopilot linked to Garmin GPS 695. Large canopy with all-round vision. Aircraft fitted with extremely comfortable Leather seats. Heating controls. Carrying capacity includes a spacious area behind the pilot, plus two wing lockers that can hold up to 25Kg each. Included for that extra safety is a ballistic recovery system that will parachute the whole aircraft down to the ground in the event of a major failure. Access to the engine is very simple with the top and bottom cowlings easily removed. Pilotaware. Spare headset. Rotax 912 ULS. 100HP. Electric Aileron Trim (Pitch & Roll). Trig TY96 8.33 Radio fitted Aug 2017. Garmin 328 GTX mode S & altitude encoder. Garmin 695 Panel mounted GPS. Dynon D10A Glass panel with Autopilot. Intercom with audio adapter.
Speeds / Weights
Vne 145Kts Empty 330Kg
Vc 129Kts Max 600Kg
Vf 75Kts Use 270Kg
Please contact me for more information.
Dean 07899 574222 / 07983 497705
Info@Wiltshire-uav-services.co.uk
Speeds / Weights
Vc 129Kts Max 600Kg
Vf 75Kts Use 270Kg
