Page 8 of 9
Re: Essential RC aero-modelling video thread (UltraHD and 4K)
PostPosted:Sat Apr 10, 2021 10:23 am
by dominicm
First flight of my FMS A-10 v2 converted to head tracked DJI FPV. The modified pilot figure doesn't quite give the pan/tilt I want but it does work quite well and does look more scale than a typical pan/tilt gimbal. Next time I'll be flying formation with some other RC jets...
PostPosted:Thu Apr 15, 2021 12:22 pm
by dominicm
My buddy, Jason's first attempt at close formation flying. Annoyingly he did much better than I did on my first attempt !
PostPosted:Mon Apr 19, 2021 8:13 am
by dominicm
So I retrofit the thrust vectoring unit and a gyro to this jet so could try out some flat spins and hovering...
PostPosted:Tue Apr 20, 2021 10:12 am
by dominicm
My buddy Trev experiments with a lot of different airframes in this size and tells me this is by far the best. Expresses that well in his flying.
Motrolfly 4330-216
20 x 8 prop
Hobbywing hv 100amp esc
Savox 1270 servos
6S3300 x 2
2S800 for servos and RX
​​​​​​​Flying weight 11 lbs 12 oz
PostPosted:Wed Apr 21, 2021 1:28 pm
by dominicm
Skill and judgement or plain simple luck? I'll go with the former. He knows what he's doing.
PostPosted:Thu Apr 22, 2021 12:52 pm
by dominicm
8S wemotec Evo fan/motor upgrade totally transforms the Freewing Avanti S into an animal
PostPosted:Sat Apr 24, 2021 10:51 am
by dominicm
After some successful flying exploring the thrust vectoring capability of the Mephisto it was on approach into land on the 2nd flight of the day when the engine shutdown at the worst possible moment. The aircraft rapidly lost speed and despite the pilot reducing flap and pulling progressively back to full elevator he could not guide the jet over the hedge at the end of the runway. A wing tip caught the top of the hedge and pitched the jet over onto the other side where it impacted the ground nose first causing catastrophic damage.
Inspection of the wreckage revealed that the UAT/bubble trap was full. The main fuel tank was 1/4 full. The flight batteries were at 70% capacity. There were no air bubbles in the fuel system. The engine shutdown for unknown reason.
PostPosted:Tue Apr 27, 2021 11:26 am
by dominicm
No doubt that adding thrust vectoring to delta wing aircraft makes them so much more agile and manoeuvrable as displayed here. Just needs 2:1 thrust to weight ratio to push out of those post-stall manoeuvres when needed.
PostPosted:Fri Apr 30, 2021 2:50 pm
by dominicm
5S on the stock ESC. Not recommended but I suspected I wouldn't be on full throttle for very long. Proven to be right. Worked fine although hovering in the cross wind was a bit like spinning a plate on a stick. 5S3000 lipo further back next time.
PostPosted:Sat May 01, 2021 7:37 am
by dominicm
There I was just testing out the Go Go Bird Eagle Ornithopter for the first time when it got attacked by a Red Kite bird of prey. No harm done. I think it actually enjoyed the encounter. :D
PostPosted:Wed May 05, 2021 3:29 pm
by dominicm
Not easy filming something this quick but I've had a fair bit of practice. Definitely over 200mph...may getting on for 250mph. Blink and it's gone.
PostPosted:Thu May 06, 2021 11:57 am
by Jim Jones
Stunning !
Scale speed?
Is anyone aiming for supersonic?
PostPosted:Fri May 07, 2021 10:21 am
by dominicm
Converted the pilot to a pan/tilt mechanism and installed the DJI FPV. Worked quite well on this first flight. A few adjustments to make before the next one...
PostPosted:Sun May 09, 2021 8:40 am
by dominicm
You don't need a flight controller but it helps with return to home, stabilisation in wind and real time telemetry.
PostPosted:Thu May 13, 2021 10:34 am
by dominicm
First flight of our twin 80mm electric ducted fan A-10 enhanced with head tracked DJI digital FPV. A challenging flight and lots learnt.
