To discuss anything which relates to the FLYER Airportal or the magazine
By Morten
#1483318
The search function forces you to use longer words than 4 characters and this has several times made it very difficult to search for something.
Today, looking at the recent woes of the e-go aircraft, I wanted to search for past posts on that - there has been some discussions on the viability of the design/project in th past.
Now, if I search for e-go it seems to ignore the hyphen and insist on interpreting it is a search for e and go which fails due to the 4 character rule. If I try to search for "e-go" it doesn't find anything - presumably because it includes the quote marks as the search?
Of course, ego would give lots of false hits (not that I'm saying that there are too many egos on the forum, but... :wink: ) but is too short and of course e-go aircraft merely ignores e-go and gives useless results.
I had a bit of fun with e-go canard (posts about restaurants and French cuisine), e-go Cambridge Composite (posts about the Firefly?!) and e-go start-up viability (posts about airfields going under).
So, how I am supposed to search for past threads on the e-go?
I understand the need to not search for words like 'the', 'and' etc., but we should be able to search for an exact phrase in quotation marks ("e-go") and it should also allow us to use hyphens, periods or other punctuation marks without getting confused.
Alternatively, instead of a hamfisted 4 character rule, just ignore the x most commonly used words (which would be unlikely to include "e-go" although they may include "ego") :pirat:
Morten
GrahamB liked this
By MercianMarcus
#1483332
Morten wrote:Hilarious!
So Google search is more user friendly than the site's own...
Cheers :thumleft:
Why reinvent the wheel, especially as you are not going to be able to do it as well as google did?
What would be nice is if the site used the google custom search API to provide a google search of the site from a search form on the site.
MM
#1483340
Grelly wrote:I'm with Morten on both his points.
You may want to think about rewording that. :shock:
(I agree with Morten, BTW, most frustrating).
Grelly liked this
By skydriller
#1490932
I have recently come across this as a problem because of the multitude of TLAs in aviation.
It does make searches for some things difficult, can it be changed?
Thanks, SD..
#1491519
I've also seen a big gap in the search over the past few weeks...it will search something very new, but then there seems to be a gap back to about 2014 and all searched items come before that. There seems to be a big chunk of time between 2014 and 2016 which doesn't appear...unless I'm doing something wrong.
I just did a search for a common term - "google" :D
The first hit I get in 2016 is:
Q codes and what they mean.
by PaulB ¦ Sat Sep 10, 2016 10:10 ¦ Forum: General Aviation ¦ Topic: Q codes and what they mean. ¦ Replies: 39 ¦ Views: 1293
The one prior to that is:
Jodel D9 1/4 share at Hinton £2000
by Thermic Rick ¦ Tue Mar 18, 2014 22:02 ¦ Forum: Groups/Sharing ¦ Topic: Jodel D9 1/4 share at Hinton £2000 ¦ Replies: 0 ¦ Views: 635
By MercianMarcus
#1491526
I don't get the objection to using google.
Type the following in the search box. Results include stuff form 2015.
site:forums.flyer.co.uk "tla"
By MercianMarcus
#1491540
Paul_Sengupta wrote:Google results don't come out with a list of posts in chronological order.
Here you go, a custom search box that only searches flyer and where you choose to list results by relevance of date (change the sort by drop down top right.
Sorry but I can't do anything about the ads unless you want to pay to use it.
https://cse.google.co.uk/cse/publicurl? ... lbwfelkvre
#1491558
Hmm, I got this date order:
Aug 21, 2016
Aug 14, 2016
Jun 25, 2010
Sep 21, 2014
Mar 3, 2016
Feb 29, 2016
Feb 4, 2016
Nov 26, 2014
Nov 8, 2015
Jul 18, 2010
Whereas Flyer search gives me this:
Mon Oct 17, 2016 12:47
Mon Oct 17, 2016 12:17
Mon Oct 17, 2016 11:43
Mon Oct 17, 2016 11:24
Mon Oct 17, 2016 11:21
Mon Oct 17, 2016 11:16
Mon Oct 17, 2016 11:15
Mon Oct 17, 2016 10:58
Mon Oct 17, 2016 08:22
Sat Oct 15, 2016 16:49
Sat Oct 15, 2016 16:37
Fri Oct 14, 2016 20:29
Wed Oct 12, 2016 23:53
Wed Oct 12, 2016 17:40
But thanks, I'll give that a go in future! :D
