Tim Dawson wrote:Have newer gyrocopters managed to somehow overcome the problem of bunting then? Or made it much harder to achieve?
The short answer is yes. The main factor to improve stability which the research identified is the vertical location of the thrust line relative to the aircraft's CofG.
Simplistically, you have two main sources of force affecting gyro stability. The rotor, which provides lift and stability as a consequence of its angular momentum, and the thrust from the engine prop. In the absence of a rotor, if the prop is displaced from the vertical CofG, it will create an unbalanced moment about the CofG, causing the fuselage to rotate anti clockwise (if situated above) or clockwise (below CofG) - that is...it will bunt.
With the rotor in place, it's angular momentum balances the engines thrust moment, so long as it is spinning fast enough. The displacement of the thrust line effectively acts as an amplifier for any discrepancy in the forces between the prop and rotor.
The problem with many designs before the Glasgow study would have thrust lines located significantly higher than the CofG. This was invariably to accommodate clearance between the prop and the rear fuselage/empennage. And consequently this would create less stable aircraft, that were more sensitive to changes in power and rotor speed.
More modern designs invariably include a bent/displaced rear fuselage, which allows for the prop to be mounted lower, resulting in a thrust line much closer to the CofG (= more stable aircraft).
GtE will be along in a minute to tell you I just made that up
